1. hot water tap in a kitchen. when i open the tap a little bit, the water runs slowly, when i open a little bit more, at certain point it shoots the water and the vibration starts. in order to stop it, have to open tap more, or close a little bit. it only occurs in a kitchen. really really drives me mad. changed the tap, same is happening. no way to do dishes without getting that vibration.
2. water temp in a shower. when heat hit uk, hot water temp in shower started to go up and down. it is all fine at the start and then it starts to go coldish, then back to hot, coldish, back to hot. and the longer i take the shower, the colder it gets at the low point.
let the water run, went to have a look at the boiler. the display was showing: yellow light on, temperature 65, then yellow off, temperature drops to 60, yllow back on, temp going up to 65, then yellow off again and so on and so on. not enjoying my showers anymore
had the same problem last year, called boiler insurer, they changed something and it was fine. now it is back again. is there a reason why it is happening again ?
if i knew that all this is cause by boiler, i would get a replacement. but i have no freaking idea !
pls help. or maybe one of you descent and honest plummers are around west london ? or anywhere in london ? cause i don't know what to do. if someone could sort the tap, i will give a little bonus on top of fee.
