- Joined
- 12 Apr 2021
- Messages
- 2
- Reaction score
- 0
- Country
Hi all - first post with something of an idea. I don't know if it's an AMAZING idea, but if you're passing with an opinion talk me into/out of it? Any comment welcome!
So, bought a house with my dream garage in it. It was INCREDIBLY well built (to my eye anyways) and has water, electric, even a toilet (yes really) BUT there is a problem, in that it has an inspection pit.
I thought to myself first thing I'll do is fill it in with hardcore, 150mm layer concrete over it, problem gone BUT then I kept on thinking and thinking... That is valuable storage space after all.
Cars in the garage will be on dollies, and are BOUND to get caught on any lips in anything as they get shoved around, so I figured on:
- Tank it: I'm thinking pond sealer or paintable DPM. Couple of layers. It is bone dry as it stands but rather pre-empt.
- Hefty box section (maybe RSJ even) in each corner, and box section every 1/2m along the edges not quite the full height.
- Weld them up to feet before they go down, winch them down, drill and bolt them to the brickwork.
- Weld box section across the top to within 16mm of full height.
- Finish the "lip" with some aluminium angle to square the top. Get it flush with the concrete floor at the top to frame the...
- ...steel road plate. One to go over the top (bolt that on into tapped holes just to stop it moving but can ultimately be removed if it HAS to be) and one removable section over the stairs.
- Paint the lot (red oxide primer?) and then store stuff down there so it can grow fungus nicely (I'll have to ponder ventilation...)
That way, the bigger road plate sits across a hefty framework of steel, as does the more removable access bit, and if it's framed to size hopefully not too much lip to catch the dollies. Hopefully. The "permanent" plate I can always seal around the edges with silicone even, and aluminium angle to frame it should last well enough.
Any ideas on it? Thanks all.
