Covering a drain inspection cover?
16 Sep 2007
London
Hi
There is a drain inspection cover in my front garden and I would like to raise the soil level around it, which would result in it being hidden under the soil.
I assumed it was a sewage drain and was therefore planning to raise the cover with an extra layer of bricks and a new frame and cover.
However I have since discovered it is just a rainwater drain taking water from the house gutters.
Would it be acceptable to just cover it with soil and perhaps leave a marker to indicate its location? Or should I do a proper job and raise the cover as planned?
Thanks for your advice.
14 Sep 2010
Rochdale
There are lots that are covered, if you know where it is and it’s just covered with soil then it wouldn’t be too bad if you ever need access.
30 Jun 2008
Suffolk
Make a feature of it by putting a planter on with flowers in it.
We have 3 in our back garden, at the bottom, so I made simple frames with raised sides and put a base in them. Drill a few drainage holes, line with double layer of weed control membrane to stop the soil falling through the holes and plant out with your favourite blooms.
If you ever need to get to the inspection cover simply lift up the planter and then replace.
