Hello
I will cut this short as the situation has been going on for 9 years so dont want anyone to die of boredom. Basically the new development I live in is a complete botch job from the first layer of cement to the roof. Mushrooms growing out of walls, incorrect stack pipes, window frames not fitted properly, everything. The situation that concerns me as I am on the top floor is the roof insulation. I was told that the reason why the top floor residents are freezing during winter (despite having double glazing) is because nothing is in the roof. Then I was told there was 120mm which is acceptable. My question is, why did my neighbour have water leaking down from her ceiling and why have I had mould on all my ceilings? I have spoken to a guy who did thermal imaging of the block I am in, and he said it is letting out loads of heat. I want to make sure I know what Im talking about before I contact my housing association, as they will try to wriggle out of any responsibility as they have before. Any advice would be appreciated.
Thank you
PS They are now replacing all the ceilings in my flat why would they need to do that if the 120mm is acceptable.
Read more: //www.diynot.com/diy/threads/cowboy-builders.432766/#ixzz3YWvQQ6mN[b][/b]
Thank you
