Crack appeared in ceiling artex
22 Nov 2006
Glasgow
Its on the bathroom ceiling and about 5 feet long.How can I repair this,short of re artexing the whole ceiling.
deac
You could try some flexible filler but it’s unlikey it will last without stripping it off & re-enforcing. A crack that size is almost certainly along the line where the plasterboard panels join & either no joint tape was used or there has been significant enough movement to open the joint up. Do you use or store things in the loft; moving around up there can sometimes be enough to open up cracks in the ceiling.
Im in a lower cottage flat,and this line keeps coming back no matter what I do to repair it :mad:
Have you tried brushing caulk into it?
Ahhh then; it could be a matter of no jointing tape as I said earlier but I suspect you have a problem with excessive flexing in the 1st floor joists. Problem is (if it’s original) the 1st floor of a cottage would never have been designed to take the weight of all the additional furniture etc. full blown living accommodation upstairs inevitably means; this can be a big problem on many house to flat conversions.
Assuming your upstairs neighbour isn’t a dancer, doesn’t hold regular parties or jump up & down on the floor, there is probably nothing you can do short of ripping up the floor & putting in additional or new & larger joists to take the extra weight.
