I am looking to get an idea of whether this crack might need underpinning and if so what are the likely cost implications ball park figure.
Please see attached photo of crack running vertically through bricks under window sill on ground floor. The crack is about 5-8mm wide at the top and tapers to nothing at the bottom about 9 bricks down.
The crack is old and there is no new movement in it. there is also a hairline crack in the sill above it which is either made of stone or concrete.
From my brief research on the internet it appears that cracks that go directly through bricks are usually caused by sudden movement.
There are no large trees in the vicinity and I believe the area is a gravel subsoil on a clay base.
Anyway, I am thinking of buying this house as project but am worried that the crack is the sign of serious problems. I know I should get a structural survey, but at this stage just wondering if it is worth it regarding how much it would cost to rectify 'v' the cost of the house.
Any advice or ideas gratefully received. thanks.
