Hi guys, had 35m2 of sand and cement screed put down in a new extension December 2013, we are just getting round to tiling quotes in.
Problem is where the screed has cracked you can see movement of a couple of mm deflection when loaded. Naturally I'm a little concerned about this, does it mean the whole thing needs to be re done or has any one successfully repaired a similar issue and if so what methods were the most effective?
Construction is as follows
100mm concrete oversite
60mm jabfloor Polystyrene
100mm quintherm PIR
Wet UFH
120mm screed
Thanks in advance
100mm quintherm PIR
Wet UFH
120mm screed
Thanks in advance
