Cracked wall tiles in shower
8 Jun 2013
Gloucestershire
What would cause the tiles to crack in my shower?
They are mounted on hardi-backer and so the backing is stable (I'd assume). This is affixed to a stud-wall.
The tray itself sits on a single 22mm board, inset into and the same thickness as the adjacent floorboards. The main bathroom door is on the same stud partition wall.
I'm assuming it's the opening and closing of the door causing slight movement in the whole lot.
I can cut out and replace the tiles but, how do I stop / minimise it from happening again?
Can you remove the plasterboard on the other side.
Fit noggings.
You could cover wall with OSB or ply sheets.
That's will brace it then plasterboard over.
Wall will be solid
If water has penetrated it will swell any timber , enough movement to crack tile, especially if they are thin.
