    Dismiss Notice
Cracks above kitchen window - brickwork.
Discussion in 'Building' started by rshome123, 7 Aug 2013.
  1. rshome123
    rshome123
    7 Aug 2013
    19
    Thanks Received:
    Cheshire
    Country:
    Have a problem that I've been putting off that I need to get sorted. If there is anyone with any building experience who can offer advice I'd appreciate it.
    Cracks have appeared over the course of the last few years in the brickwork mortar above the kitchen window.
    This, I am recently informed, is because when the UPVC window was fitted, they did not fix an adequate lintel (if any), and therefore the brickwork seems to have been supported just by the window (eeek yes I know!).
    [​IMG]
    [​IMG]
    One builder I've spoken to on the phone (i.e. described the problem - he's not seen it) reckons it wouldn't cost £200 - £250 to correct, which implies a days work.
    Another builder who came round this afternoon hasn't provided me with a costing yet, but reckoned it would be more like 2 1/2 days work, involving scaffolding etc, which implies it will be much more costly.
    I'm getting a couple of other quotes done tomorrow, to compare.
    My concerns are (as you might imagine)...
    1) Getting good value for money
    2) Good Quality job
    3) Disruption and any interior decoration required to be done afterwards.
    Thoughts please anyone ?
  2. Sponsored Links
  3. tony1851
    tony1851
    23 Feb 2012
    9,389
    Thanks Received:
    1,403
    Manchester
    Country:
    Get a few more estimates.
    It's not a big job, but that doesn't mean builders will be prepared to do it for peanuts.
  4. Jackrae
    Jackrae
    20 Nov 2012
    2,016
    Thanks Received:
    326
    Dumfriesshire
    Country:
    There appears to be mortar under the line of bricks immediately above the window with suggests there might be a catnic type lintel fitted.
    From the line of the crack I'd think the problem might be a subsidence issue which is more serious than you're hoping.
  5. tony1851
    tony1851
    23 Feb 2012
    9,389
    Thanks Received:
    1,403
    Manchester
    Country:
    Have to disagree there! It's the classic case of insufficient support over the window, due to no or insufficient lintel.
  6. ^woody^
    ^woody^
    3 Sep 2006
    27,526
    Thanks Received:
    3,458
    West Mids
    Country:
    It's two men for one day plus no more than £100 materials
  7. stuart45
    stuart45
    13 Sep 2008
    2,833
    Thanks Received:
    379
    Somerset
    Country:
    Does look more like a felt tray than a catnic.
  8. rshome123
    rshome123
    7 Aug 2013
    19
    Thanks Received:
    Cheshire
    Country:
    Thanks for the info. I'll post an update tomorrow.
  9. rshome123
    rshome123
    7 Aug 2013
    19
    Thanks Received:
    Cheshire
    Country:
    Not a Lintel problem... just needs repointing.
    Thanks.
  10. Sponsored Links
  11. ^woody^
    ^woody^
    3 Sep 2006
    27,526
    Thanks Received:
    3,458
    West Mids
    Country:
    Who said that?
    Why has it cracked then?
  12. rshome123
    rshome123
    7 Aug 2013
    19
    Thanks Received:
    Cheshire
    Country:
    House movement over the years.
  13. noseall
    noseall
    2 Feb 2006
    35,731
    Thanks Received:
    2,256
    Staffordshire
    Country:
    It has been recently re-pointed and has since cracked.
    How do you explain this?
    The crack is indicative of bricks dropping due to window head loading and sagging, i.e. no lintel or failed lintel.
  14. cotswoldbuilders
    cotswoldbuilders
    22 Sep 2011
    784
    Thanks Received:
    166
    Gloucestershire
    Country:
    There might be a cast in situ boot lintel which should be carrying the inner skin of brick/blockwork.
    Years ago the face work would have been build straight over the existing windows, either heavy framed timber or crittal windows.
    The movement occurs after removal of the existing and refitting with the upvc units which wont take the weight, plus you will notice slight bowing of the head of frames.
    Its not a big job to fit a lintel.
  15. RonnyRaygun
    RonnyRaygun
    4 Apr 2008
    1,672
    Thanks Received:
    239
    Hertfordshire
    Country:
    Doubt there's a boot lintel. It looks like quite an old property and boot lintels are usually only found in properties from the 60s and 70s.
    Agree though that this is due to installation of a UPVC window that is unable to take the weight of the brickwork.
    No lintel was required before, and the window installers should have advised on the installation of a lintel prior to fitting window.
  16. ^woody^
    ^woody^
    3 Sep 2006
    27,526
    Thanks Received:
    3,458
    West Mids
    Country:
    Get surveyors opinion, not one off a circus clown
  17. cotswoldbuilders
    cotswoldbuilders
    22 Sep 2011
    784
    Thanks Received:
    166
    Gloucestershire
    Country:
    You could be right Ronny but, there was an estate of local authority houses not far from me which had the same problem.
    All the Critalls were changed for upvc, hence the movement, which had to be rectified later, as you said it should have been picked up by the window company, as fitting the lintels would have been easier at that stage.
    The brickwork looks similar, but there was a concrete lintel carrying the inner walls.
    There was astos dpc, cavity tray draped over lintel onto head of existing frames ( which Stuart mentioned ) and face brick built over.
  18. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
