Cramer fugi sealing tools
4 Apr 2010
Humberside
When using these should you cut the nozzle the same diameter of the profile of the smoothing tool your using
No, just cut as normal. It’s the speed you pull the tube at that will dictate the thickness of the bead.
I know some people will say otherwise, but I always spray the bead with water with a few drops of fairy liquid in it, and also spray the Tool every time. Make sure you have a kitchen roll handy to keep wiping your tool !
