Crimp???
mo2
25 May 2006
Birmingham
If I use a regular crimp, heatshrink and then self amalgamating tape for a crimp joint. Can it be plastered over or should i enclose it in a jb or similar. Searching has confused me more than answering my question so can you just confirm for me.
dingbat said:
422-01-04 Every termination of live conductors or joint between them shall be contained within an enclosure selected in accordance with Regulation 526-03-02
Does self amalgamating tape count?
To expand on what dingbat said:
Every termination and joint in a live conductor or PEN conductor shall be made within one of the following or a combination thereof:
a suitable accessory complying with the appropriate product standard
an equipment enclosure complying with the appropriate product standard
an enclosure formed or completed with building material which is non-combustible
an enclosure formed or completed by part of the building structure.
Every connection shall be accessible for inspection,testing and maintenance except for the following:
a joint designed to be buried in the ground
a compound filled or encapsulated joint
a connection between a cold tail and the heating element
a joint made by welding, soldering, brazing or compression tool
a joint forming part of the equipment complying with the appropriate product standard
So, a compression joint (crimp) does not need to be accessible and if it is within an 'enclosure formed or completed with building material which is non-combustible' (plaster) then it is fine.
Davy
Beats me!
But that's how it appeared in mo2's post of 8.39....
securespark said:
Beats me!
laziness really...
I hate the word 'amalgamating' and like the word 'waffles'.
[Sings happily]
"bird's Eye Potato Waffles, Waffly versatile!!"
Regardless of what you can and can't do within the current regs IMO your proposal is a bodge.
Why does the joint have to be be in wall, surely there must be a better alternative?
like? (there is no ther way, but to replace the whole run of cable, which is not possible)
From a relatively lay viewpoint, this doesn't appear to be a bodge.
Doing a half-hearted job for reasons of laziness and/or incompetence would be a bodge, but isn't a suitably protected (from moisture) crimped joint a legitimate method to use in the circumstances?
