Just fitted some new radiators using 10mm Cuprofit Copper Pushfit connections with 10mm microbore soft copper pipes.
Been very stupid and despite buying and unpacking the pipe inserts, i clearly forgot to insert them into the pipes!!! -Ooopps
Not only that, but because of the limited space i had for the pipes, i ignored the other bit of fitting advice and didn't leave the required space between fittings and the wall etc to get removal tool in! Oopps
My question is, will I get away with it or am i going to be swimming when I refill the system.
Any advice will be appreiciated!
Ian
Ian
