Don't worry that's normalvivyorks said:Just had another look at the purlin. The place where it is cut has twisted a bit and looks like fixing will be difficult.
Yes.It has also had a screw put through the cut from the underneath going upwards. You can see part of the screw in the opening that has now appeared. When you say attach the wood to the purling, do you mean from the front to the back?
You go though the thickness of the timber, so you have a timber thickness of 2" + 3" purlin + 2" = 7", so will need at least 8" coach bolts to allow to tighten the timber connectors as well or better still use stud bolts or known as threaded bolt then cut off the length you need. Available from Screwfix from 300mm to 1000mmIf I go upwards I would need a bolt a foot long!
Also a bonus is to hire a couple of big G-Clamp will hold all the timber in place temparory while drilling
From your photo they look like 8"x2" but 6"x2" will be okay.The purling is 6"x3", should I get the wood the same size and attach it to front and back?
I don't know but it's no harm in buying the materials and see how you get on, you will need another person to help you, if you're still not sure get back to usI just want to make sure I`m following your instructions right. Also, do you think this is a job I can do? I am a woman but not frightened to get stuck in.
Viv.
