Does anyone have any advice on the best tools and methods of cutting this large hole ? It's to re-locate my bathroom extractor fan.
I would cut a 150mm hole in a piece of plywood and stick using gripfill or similar, especially around the hole, above.
Wait until it has set and use a jigsaw from above.
You will need the plywood to fix the fan anyway.
I tend to find downlights and lathe/plaster are not the best of friends for a number of reasons. The very best possible solution would be to replace the area where the light/lights are to be fitted, with plasterboard or fit non-recessed lighting.
not sure how that would help
