Consider a standard 1700mm long by 700mm wide steel bath. If installed the bathroom door will just slightly hit it and so the door will not be able to go back to the wall when opened.
All the bath would need is, from the corner, a nip out of the length of 25cm and going into the bath a distance of just 2cm.
Has anyone had to do this, was just wondering if you had any comments.
Thanks.
Thanks.
