    Dismiss Notice
Cutting 70mm hardwood in two with circular saw?
Discussion in 'Wood / Woodwork / Carpentry' started by purpleroad, 13 Apr 2017.
  1. purpleroad
    purpleroad
    12 Dec 2016
    440
    Thanks Received:
    3
    Country:
    Bought this nice piece of hardwood to size but need some more. The timberyard said they could sell me 70mm wide bits of hardwood but is it easy to cut that in half with a circular saw? I mean I would have to make a piece of baton as the fence and is 70mm wide enough?
  2. foxhole
    foxhole
    14 Mar 2006
    15,507
    Thanks Received:
    1,699
    Kent
    Country:
    How would we know if it's wide enough without you giving the dimensions of what you need?
    In half in which direction, Length width or depth?
  3. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,040
    Thanks Received:
    452
    Country:
    Depends on accuracy needed
    A bench saw will do it accurately compared to a hand held circular one
    Most hh circulars have a T guide that you can use but it tends to be not so good
    Or find a long bit of metal to use as a guide
    Shop around? See you f the local school have a wood workshop and the tech would cut it for you for a bottle of plonk?
  4. purpleroad
    purpleroad
    12 Dec 2016
    440
    Thanks Received:
    3
    Country:
    The width so half of 70mm is two 35mm cuts. But setting a fence to do it accurately would be difficult wouldn't it?
  5. foxhole
    foxhole
    14 Mar 2006
    15,507
    Thanks Received:
    1,699
    Kent
    Country:
    You won't get two 35mm from a 70mm , blade will be 2-3mm wide.
  6. Sponsored Links
  7. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,040
    Thanks Received:
    452
    Country:
    As said, you need to allow for the cut
    But if the loss is acceptable, practice on an offcut to get the setting right
  8. big-all
    big-all
    12 Jul 2004
    17,907
    Thanks Received:
    1,354
    Surrey
    Country:
    first thing to do really is ask the timber yard if they can rip it down as they will only generally quote whats in stock
  9. mwatsonxx
    mwatsonxx
    6 Apr 2017
    785
    Thanks Received:
    50
    Country:
    Nigh on impossible with a hand held circular saw. It needs to be ripped on a proper saw table, and as someone else has mentioned you have to allow for the kerf of the saw. You cannot get 2X35 out of a piece of 70mm.
  10. Roger928
    Roger928
    10 Aug 2016
    2,631
    Thanks Received:
    201
    Country:
    A band saw will give you close to 2 x 35mm pieces.
    The tuff saw supertuff premium blades are only 0.8mm.
  11. JobAndKnock
    JobAndKnock
    30 Sep 2011
    4,023
    Thanks Received:
    821
    Lancashire
    Country:
    Not impossible, just difficult, as any site carpenter will probably tell you, and difficult to do with any degree of accuracy unless you jig-up. Helps if your saw is fitted with a decent rip blade (low tooth count) and dust extraction
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
