cutting a square out of tile
17 Feb 2008
Berkshire
would a jigsaw blade be best option, if so how do you support the tile while cutting?
Ideally you want to use a diamond blade in an angle grinder. Start the cut from the tile face..... do as much as you can, then finish the cut from the back of the tile - easy. :wink:
You can also drill a hole at each corner and then use a tile saw threaded through the hole, using a tile file to smooth off the edges.
Diamond blade in angle grinder every takes 10 seconds for a nest cut. Hand saw will take ages
