What is the best method of cutting curves in tiles?
15 Apr 2007
Norwich
Hello,
I need to cut small curves into three tiles to fit around my bathroom sink, which will act as a splashback. The tiles are normal ceramic tiles about 200mm wide. I have used a hand saw in the past which took ages.
Is there a quicker and better way of cutting curves? I have seen tile cutting jigsaw blades and was wondering if these give a nice clean cut? Or would a tile nibbler be a better tool to use?
Any advice would be great!
Thanks,
Glyn
If i had quite alot of tiles to cut i could justify buying an angle grinder, but since its only three tiles i was hoping for a cheaper option.
I think i might try the carbide edged jigsaw blades but im not sure if they give a nice finish to the edge of the tile.
If the tiles are thin you could nip the curves out,you can get away with it being a little rough a bead of silicone will hide it.
Carbide jigsaw blades will still break out the edges a bit but as above you will not see this when siliconed over.
