- Joined
- 11 Jan 2004
- Messages
- 194
- Reaction score
- 5
- Country
I need to cut largish quantities of sheet card that is used to back picture mounts. It is smooth surface ,1.5 mm thick . I would like to cut say ten sheets thickness at a time into 12 X10 pieces. I have designed a jig for this but need to know what tooth blade you feel would be best for this ? The total thickness of card sheets together as a layer being cut would be about 15mm. There should be little if no breakout because the card is being cut as a pack but possibly the top sheet might have some.
James
James
