Cutting in, why is it is faded?
18 Sep 2006
Lancashire
I have freshly skimmed walls, done the 1st 3 coats as per instructions on here, and now, have done my first coat in the coloured Matt. I always find this happens, my cutting in line especially along the top of the walls always needs another coat, that's not a problem as sometimes the walls could do with a second coat also, but, this time I have had excellent coverage and sadly the same scenario, my cutting in line needs another coat but the walls are excellent, where am I going wrong?
I do a deep cutting in line and feather it out so there is no visible line as such it's just that some parts, very close to the ceiling are a little faded. I won't be able to do just a second coat of cutting in as this would definitely stand out so will now have to do the whole lot, unless, anyone has any tips.
could it be that dust is picking up from the surface?
Brushes and rollers have different characteristics. Best getting your roller right to the top if you can. Use a small one with a flat end.
As joe90 mentioned. The roller lays a heavier coat, hence the shading problem.
I tend to take the roller within 50mm of the seam, cut in with a few heavy coats and then dig out a mini roller and cover the cutting in and main roller area.
This allows more paint on and gives the textured finish that a roller does, virtually to the seam.
It could be where you've lapped onto the top of the wall from the ceiling. The white paint then acts as an undercoat which changes the appearance of your finish coat
