I have replaced quite a few of my misted sealed units over the past year or two but one or two of the beads could do with replacing as well. I have sourced some of the correct beading - it’s internal, rounded beading for Rehau frames. I’d originally thought cutting the 45 degree ends would simply be a matter of using a fine saw and a small mitre block. However, looking at the cut this gives looks a bit different to the end shape of the original beads. Is there a bit of kit that I can get to make sure the angle is cut correctly?
It looks as though the vertical 45 degree cut the mitre block gives is not correct and there is also an angle away from a vertical cut required (If that makes sense )
Thanks for any help.
