cycling showers
11 Jul 2012
Humberside
Hi all,
Last year, my old shower (an 8.5kW unit that had been installed years ago, before I bought my house) started cycling from scalding to freezing. For various reasons, I put off replacing it until recently, when my step-father (a qualified plumber, no longer in the trade) fitted my brand new Triton Seville 10kW unit.
My problem is that it is also cycling hot to cold, regardless of the temperature setting on the unit. The troubleshoot in the manual says this is due to lack of water getting into the system, but the water pressure is fine.
I haven't had the wiring replaced for 10mm cable as I didn't know I was supposed to until after the unit was installed. But even if this could cause cycling of the new unit, why would the old unit have the same problem?
Any advice would be greatly appreciated.
Many thanks
Did plumber flush pipework, any sediment could cause restriction in flow.
Thanks for the reply.
I'm pretty sure he did. In any case, he's ad a look since and said that the water flow is ok. It's just strange that it's doing the same thing as the old unit, could the new unit have a faulty thermostat?
Triton provide a service back up , give them a ring, if it's faulty repair is free on new units.
