'D' handle or 'Pistol' handle rotary hammers for DIYers?
29 Aug 2011
I've found some of the D-handle type rotary hammers to be smaller in length than the pistol-handle type. Of course, the former has more power & weight, and sometimes reduced-vibration technology.
Has anyone used these D-type hammers for strictly DIY stuff, and found them to be advantageous over the pistol-handle types? I am assuming that the D-types being a few mm shorter, can be of some benefit. I've attached relevant pictures for reference.
D-handle type:
View media item 37235
Pistol-handle type:
View media item 37236
I don't think either is much different in use as you tend to use both hands and so they both feel the same, with no balance or power issues when you are drilling
If you look at the specifications for any SDS, then its the Joules that matter more than anything, as that is the actual force that the drill can make. And you can get a high rate with either design
@^woody^: yes, both the designs have almost similar specifications, that's why i was thinking if i should draw the comparison at design level.
Down to personnel perference then really. As said you are most likely to use both hands but myself I find the pistol type to be easier to use on those times when your other hand is perhaps holding that piece of timber that you're actually trying to fix. No doubt others will feel completely the opposite :confused:
