dado angles
17 Dec 2007
Im fixing a dado to run up the stairs. First it runs straight along a wall into a corner before it then runs up the stairs on another wall.
If it was just running straight along two walls I could just do a simple 45 degree cut for a corner but the corner cut I need is obviously on a 45 and then twisting up...how do I do it?
in a word doing it properly you can't change angles on two plains at once
you need to seperate them by a few inches
somtimes that will mean you start the rise around the corner or a vertical section to line the parts up properly at the correct height if the step is at the corner
i'd agree that can't be done. The reason being that if you had dado that was 50mm wide and you make a 90deg cut, the cut length is 50mm, whereas if you make a 45deg cut, the cut length is 70.7mm so they don't sit together. The answer is always to halve the angle and make two cuts the same angle, thereby giving the same cut length.
In your scenario, you're ok in one plane, where the walls come together you can cut two 45deg, but where the dado comes down the stairs, you're gonna have a 50deg(ish) cut running into the corner where it will meet a 90deg cut so they won't match.
The solution is to run horizontally into the corner, come out the other side horizontally for 4 or 5 inches, and then change angle to run up the stairs.
