I only looked under the floor in one place as I didn't want to take up all the laminate flooring (or rather the wife doesn't want me to). However, what I could see of the walls under the floor they appeared to be concrete and wider than the wall built on top if that makes sense. The concrete comes to just under floor level.
I don't know what is meant by oversite so I can't answer this but yeah, I would say you could crawl around down there as there seems quite a lot of room.
There are three unobsructed airbricks at the front and rear (6 in total).
The plaster going all the way to ground level would be an obvious cause so I will check this out.
I appreciate the responses lads.
