JohnD said:If you lived in Gloucester it could be even scarier.
Then you need to find out - it makes all the difference. For example, if some debris was bridging the cavity and either soaking water up from below, or from a leak above, then this could be a cause.No23 said:Also, I'm unsure if the party wall is single brick or cavity wall though I don't know if this would make a difference or not.
If the second damp path is close to the first one, then it's possible that they're related.I also have damp appearing in the front sitting room.
Sorry, I hadn't realised that they were different walls.It's got me stumped as those photographs I posted are in three different areas and all on different walls.
No23 said:...I live in a mid-terrace about 100 years old. ..
Yup - I'm obviously not reading thoroughly enough today.JohnD said:No23 said:...I live in a mid-terrace about 100 years old. ..
It won't be a cavity wall, then.
Indeedy! It will be either more wet or less wet, and it's an essential part of the diagnosis to find out which it is.I really want to know how wet it is under the floor
I know the reason behind this, but it conjures up an image of someone in a ten-gallon hat - and I mean literally.JohnD said:__________________
The original JohnD
No23 said:In regard to chemical dpc's, I would be very reluctant to go down this route anyway as I have experience of having this work done in a previous property I owned and it did nothing to solve the problem (which turned out to be penetrating damp).
