Much of our Victorian house has had injection treatment but in a couple of places we have damp regardless - mainly in our utility room which is clearly a later addition. Initially I figured the treatment had simply failed but a handyman mate suggested otherwise and I think there are two possible factors, I'd welcome input on from more expert folk...
A related issue is that where the socket is in this room, the damp appears to have climbed from the floor up and around the socket. Is it plausible that fitting this cable has breached the injection treatment?
- The house generally has the internal floors 6-12" higher than the ground outside i.e. the bottom course of bricks has ventilation bricks to the under-floor void. I assume this is done for good reason so that damp has to rise rather than being able to penetrate from the soil, is that correct? I notice the utility room, clearly a later addition, doesn't work this way. The room has a concrete floor seemingly at ground level so the row of injected bricks is actually one or two courses higher than the internal floor. To me that suggests it will not stop water coming up the bricks and into the concrete, i.e. it will stop the damp climbing up the wall but won't keep the room dry?
- The outside of the house on this side has a large concrete yard which comes right up to the house. My mate says this gave rising water nowhere to go, and helped it get into the house. He suggested a fix is to cut a channel 6-12" wide around the house, filled with gravel, presumably to act in effect as an air-gap? In fact with my previous point this would actually sort of 'lift' the floor inside higher than the ground outside too.
