We have a garage building with some damp issues.
Some background:
Down one side on the outside there is raised beds that butt against the garage wall.
At one end there is a raised patio that is almost certainly above the level of any damp course (if there is one). Also at this end the guttering down pipe appears to take all the roof water into a soak away (i can't see the water draining into either the main drain or the old cess pit in the garden). Currently the soak away appears blocked as there is standing water in it - though this is only recently appeared.
At the patio/soakaway end there are damp spots (small circles) in a thick line that are above the patio level outside (which as mentioned above is above any damp proof line.
Question 1) Obviously i know i need to unblock the soak away. It drains under the raised patio to is it just a case of getting my hand down the drain and removing as much silt/debris as possible until the water drains away?
At the other end of the garage there is similar damp areas that start above the ground level.
Any ideas on how to proceed?
Question 2) How do I check to see if there is a damp proof course (sorry i'm a bit of a newbie). The whole building is rendered (an plastered on the inside) so i can't spy any dpc from the outside?
Some background:
