damp on chimney breast
M
marsaday
i have damp again on the chimney breast in the attic bedroom.
i thought it was the chimney leaking and so redid the pointing last autumn. however the damp is coming through again.
could it be the flashing?
also would i need to put a vent hole in the wall ? the chimney is used by the gas fire in the lounge so gases will becoming up it.
M
marsaday
i re-pointed the stone work as it was mud !
the top was in good condition with 2 little metal breather cowls (holes in them).
the flashng didnt look that good though.
22 Jan 2010
Worcestershire
long as lead is not split and the is 3 inch cover on tile wont be coming in from there , prehaps stone work has become pourus but i doubt it , is the cowel pots seated and pointed nicely no cracks etc , and have you got a pic ??
6 Aug 2008
Bournemouth
Absolutely concur also, if the damp staining is brown, the years of wood/coal burning will have left deposits up the chimney brest that will undoubtably bleed through the brickwork.Only way out is hack off back to substrate and waterproof render then skim finish.
22 Jan 2010
Worcestershire
not in the best of conditions also looks like you have lead soakers and there s not enough cover of lead goin to them , also is there any damp on the perling in pic 3
22 Jan 2010
Worcestershire
dont think thats problems is exsisting damp in bricks of that summat salts . any way to the problem at hand that flash band deffo need s replacing only last 12mths any how.
M
marsaday
i think the chimney breast is damp because of old flashing and so i will sort that.
what about the other damp/black mold underneath the roof towards its end (small wall). could this be due to the bad pointing or is it condensation?
