Damp patch on newly skimmed wall
29 Dec 2010
Tyne and Wear
Just had my kitchen skimmed, waited for the skim tto dry then applied the mist coat. Few days later I have noticed that the top of the wall looks like it has a stain, this has continued to get worse, the plaster is soaking. It's on a external cavity wall, any ideas what could be causing this as before it was skimmed the wall was bone dry.
Directly above the damp is the bathroom toilet. Does this look like a leak or the plaster drawing water from wall
Thanks in advance
Mark
This is most certainly a leak from either the bathroom upstairs or an external gutter missing or a damaged roof. Have you a damp wall in the bathroom at floor level and above? If not it is a leak from some pipework in the floor so I would recommend you get that resolved as soon as possible. If it is left you may need to re plaster your wall as the plaster will start to bubble.
On another note I am not seeing much ventilation in your image. Have you got ventilation in each room?
Thanks for your reply John, yes I have an extractor fan at the other side of the kitchen window, just had a full new kitchen install hence the walls being skimmed. No sign of any damp in the bathroom as it's all tiled. I can't get under the boards in the bathroom as they are all tiled so guessing I'll have to cut a hole in the ceiling and investigate from below.
Mark
Mark
Yes Mark I think the only option unfortunately will be to cut a hole in the ceiling. Its not ideal but I think you will quickly see you have a leaking pie just above it. Also just before you do that run your hand along the back of the toilet upstairs where it meets the floor and do the same for the sink just in case there is water leaking from one of them and running along the ceramic where you will not see it and straight into the floor. But from what I can see in your images its a fairly big leak so possibly not that but worth a try before you pull your ceiling down.
Thanks again John, I've made a hole and the ceiling is dripping wet around a half meter square, got a plumber coming this afternoon. Just one more question, will the ceiling need to be re boarded and skimmed or will it dry?
Mark
Mark
Mark typically its very difficult to patch in a ceiling. If it was me i would redo the ceiling but it really depends on how good your plasterer is. Half a meter square hole is a big patch but talk to your plasterer.
