Hi - We have an old property with a DPC, we have taken a path away around the house to expose old red brick below DPC level and need to waterproof them. The house is showing minimum damp levels at skirting board height only and not of great concern, as all the guttering and drains were blocked an overflowing so it should be resolved with clearing and removing the path. We have looked at paining on Synthaprufe, but it is quite expensive and wonder if there is anything cheaper, but still as effective?
We also have to tank an inside wall, which it is below path level from the window down and wonder if we would use the same stuff and then replaster over it?
Thanks for your help - as you can see we are complete novices!
