    Dismiss Notice
Damp smell after leak
Discussion in 'Plumbing and Central Heating' started by worthchanging, 11 May 2017.
Tags:
  1. worthchanging
    worthchanging
    16 Jul 2014
    12
    Thanks Received:
    London
    Country:
    Hope this is the right section of this vast forum.
    So in my storage cupboard, there has been a leak from a pipe that runs through it. A plumber has replaced the pipe so I am pretty sure the leak is gone. However, this wasn't done immediately so the leak has gone into the wall (the wall is between the cupboard and bathroom btw, but I really hope bathroom is not contributing here!)
    The problem is some damp smell which I believe is just residual (from water in the wall). It's a tiny cupboard (full floor to ceiling but just 60cm x 60cm area) and of course no smell when the door is shut.
    I have put a small but supposedly efficient dehumidifier that's been running behind the shut door for a week or two now, almost 24/7. I think it may have improved the situation a bit but can't be sure.
    Now, what is the best way to get rid of the smell, assuming there is no active leak? Put in a massive dehumidifier? Keep the door open (with the dehumidifier off)? Anything else?
    I'd really like to get this sorted in a couple of weeks or so..
  2. JohnD
    JohnD
    15 Nov 2005
    63,067
    Thanks Received:
    3,332
    Whale Island
    Country:
    Cook Islands
    post some photos. Indicate where the damp is.
    Water runs downwards so may be in the floor. Floor coverings may prevent it drying out. Wooden floors may hold less water than concrete.
  3. kevplumb
    kevplumb
    18 May 2004
    23,714
    Thanks Received:
    925
    depends where i get sent
    Country:
    yeah change off for on
    if air can't get in damp can't get out
  4. worthchanging
    worthchanging
    16 Jul 2014
    12
    Thanks Received:
    London
    Country:
    Well the damp would go into the dehumidifier container which I've emptied twice so far, wouldn't it ?
    And if I open the door, won't I be dehumidifying the world instead of the closed cupboard space? I would have thought it's more efficient to keep it shut if the thing is switched on.
    Will post photos once I get round to it shortly..
  5. Madrab
    Madrab
    4 Oct 2012
    6,274
    Thanks Received:
    1,645
    East Renfrewshire
    Country:
    Your dehumidifier will remove the moisture from the air but it won't help with speeding up drying the wet area, that needs ventilation/air movement around it to do that
  6. HERTS P&D
    HERTS P&D
    9 Apr 2010
    9,901
    Thanks Received:
    1,475
    Hertfordshire
    Country:
    Stick a desk fan pointing into the cupboard, it will be dry in no time.
    Andy
  7. dilalio
    dilalio
    20 Mar 2009
    6,417
    Thanks Received:
    909
    Potters Bar
    Country:
    Close the door to the cupboard and go out... perhaps down the pub; whilst there's still a few left! :rolleyes:
    • Like Like x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
