can any one explain how to simply connect a 15/50 pump upto a pipe stat so that the pump comes on when solid fuel fire is heating up heat exchanger
cheers
Live feed to common, Switched live from normally open to pump. If you cannot work it out from the wiring diagram in the stat, should you be doing the job?
