- Joined
- 17 Feb 2006
- Messages
- 375
- Reaction score
- 2
- Country
I had a stuck TRV (rad cold). Found some instructions, got the plastic shroud off.
Pushed the little pin in and out a bit. Thought I'd give it a thorough waggle with pliers. The pin came right out. Then a bit of a leak through the hole it left. Put the pin back in. Doesn't seem to leak now.
It didn't actually feel like I broke anything. Is that pin 'meant' to come right out? I'd rather not replace the whole valve if I don't need to. Or can you just replace the brass valve bit without replacing the valve casing?
Thanks.
[/img]
Thanks.
[/img]
