Hi, I've got a heat only boiler and hot water cylinder on the second floor of a block of flats. The pressure isn't great so I have a Salamander RHP45 pump which helps out.
Yesterday, my girlfriend left the immersion on all day and only realised when she had filled a sink up with very hot water. Since then the pump hasn't worked, I'm assuming because the maximum it can handle is 65 degrees. The two Controlmatics show a failure light.
Does the pump need totally replacing? or is there a part that can be replaced? Any help would be gratefully recieved.
