Problem: Mira Sport 10.8Kw shower suddenly packed up.
Symptoms: No lights (not even "standby"), no action. Nothing. 240V showing as far as thermal cutout above heater tank.
Block circuit diagram http://www.mirashowers.com/onlinecatalog/pdf/p3279_2a.pdf doesn't show enough detail to work out exactly what's going on inside. I suspect the cutout, but would that cause everything including standby lamp to die?
Is this the likely cause? Thanks.
