L
longdogs
Hi all
I have recently moved into a Victorian terrace, fully aware that there was a damp problem in the lobby. I want to get this problem sorted before decorating and ultimately to lay new floor tiles.
This is a pic of the damp floor (the dark patches) this damp 'pattern' doesn't really change whether the weather is dry or wet.
I have lifted one of the floorboards adjacent to the tiles. See below:
I have inserted a long screwdriver through one of the mortar holes and behind the brick foundation it appears to be hollow or maybe sand? There is a concrete layer under the tiles.
At the bottom of the foundation, there is a steel water main entering the house. The pipes is damp where it goes through the bricks but nowhere else.
I am not sure whether the damp is coming from the pipe on the other side of the wall or elsewhere.
I have been told to dig up the tiles and lay a dpm but I am not sure that is the correct thing to do in a house this old as the damp could just be forced elsewhere. I was wondering about removing one of the bricks to see if it will dry out naturally. Airflow under the rest of the house is good.
What would be the best way to proceed - starting with the least disruption first.
Below is a pic of the outside where the pipe meets the main stop valve. If the whole floor has to come up, I would like to replace the steel pipe with plastic but not sure how I would be able to connect without also disturbing the tiles outside. See pic:
Just cautiously looking for advice and ideas at the moment so any help would be much appreciated.
Many thanks.
Many thanks.
