Found answers to my previous question a couple of days ago by looking through previous posts (doh!).....but now got another one which I can't find an answer to!
I'm doing a freestanding deck 3.6m square. there's no patio underneath so I'm going to support the framework on posts set in concrete. I'm a bit confused about how much support is needed though. I followed Thermo's advice (lots of other brilliant tips going through the posts - thanks) to look at www.richardburbridge.co.uk and the decking showed there has supports (concrete slabs) at 1.8m points round the outside of the frame but not all the inner joists are supported - they're just connected at their ends to the outside. Is that right? I'm thinking that my deck will only be a few inches off the ground so I could use the slab method, but wouldn't using posts also follow the same principle?
I'd like to avoid having to dig down deep enough to put a joist support about half way along the deck to then lay the joists on top.
