Howdy doo.
Having spent a year now, bashing away at the innards of our house, me and the mrs me are turning our attentions to the garden. One project we have in mind for the less-cacky weather time is to create a raised deck/veranda area around the front and side of the house.
The house is on a slight slope, with the ground floor level being approx 500mm higher than the outside ground level. We were hoping to run a 2000mm wide deck out from the house at internal floor level, incorporating a set of steps that project out over the existing concrete ones.
My initial plans were to fix a wall plate to the external wall of the house to carry the joists and to sink posts in the ground as necessary. I'm pretty confident as to the method of constructing the rest of the deck (thanks, largely, to this site!
). The house is a 1930's semi - bricks/walls are in sound condition as far as I can tell - no crumbling, if this helps.
Reet. Questions:
1: Is it ok to fix the wall plate to the house or would it be better to just use posts for all the load bearing support?
2:If I did use a wall plate, would I need any damp-proofing between it and the wall (the wall plate would be a couple of brick courses above the DPC)?
3: what method of fixing would I need to use to attach the wall plate, if I did go down that route?
4: Are there any BC/BRg's issues that I would need to resolve before starting?
Thanks for your time/help!
WC
Reet. Questions:
WC
