New here..hope folk can help!
I live in a detached house in the countryside - middle of nowhere.
To the front of my house is a grass garden that goes 10 metres forward from the house and 30 metres either side of the house. If you carry on forward you end up in a fenced off 2.5 acre field that is also ours
I'd love to put some decking in the FRONT garden. We live in a conservation area, but there are no Article 4 restrictions in play.
5 metres to the right side of my house and 5 metres forward is where I'd like to start the decking...
That is ground level and it's the level the house is at. I know I can go up 300mm from this point. And I will. The decking will go forward from there. Forward of this is a drop off as the garden slopes radically down, so the decking will be less than 300mm up from ground level at the back...it will go forward at the same height and will be about 2 metres off the ground where it finishes...underneath here will be ideal for storage!
It will stop just short of a stock fence line running right to left that leads in to a 2.5 acre field also to the front of the house (referenced above)
Having read the regs, as follows..
. None of the decking or platform is on land forward of a wall forming the principal elevation
PROBLEM: I have read up on this. My understanding is I need planning permission because the decking is in front of the building line of the house? Surely that cannot be right?!? The decking isn't attached to the house...it's in the garden
I understand in the city it might be unsightly to have decking in front of the building line...but in the country where I'm 1/2 mile and 6 fields away from the road?
I can only imagine I am reading the regs wrong, but equally I suspect not
In my travels I do visit addresses in the countryside and see alsorts of things in front of the building line. Am I to presume they all required and got PP and BRs or have I totally read this wrong?
I've spoken to a couple of decking companies who tell me decking is a temporary structure and 'it will be alright'...
We shall see..
Thoughts, anyone?
- The decking is no more than 30cm above the ground
- Together with other extensions, outbuildings etc, the decking or platforms cover no more than 50 per cent of the garden area.
We shall see..
Thoughts, anyone?
