Right one of the jobs I want to use for assessment has some defects.
I've replaced all primary rings, done the earths, CU, RCD and the immersion / bolier feeds.
Client didn't want the lighting touched due to cost / hassle since the switch cabling is behind the door architraves and would require new chases / replastering etc.
I've tested the cable and is is functional for the light loads (pun there
) however the cable is all twin no earth.
Am I right in thinking that as long as I show the circuit as defect then the assessor won't mark me down for it. The client is aware that the work will require doing, but won't have the ££'s for another year or so.
If the defect was unsafe I would insist, but since none of the current light fitting (all simple BC) require an earth is this an 'issue'
