I've a Deltabell WE siren with the square 3V batteries. Is it possible to remotely locate the batteries and connect to the circuit board with a long, say 3m, lead. If so what connectors would be needed?
My Deltabell unit does not have a 12V (11.1V to 13.8V) connection on the PCB. Soldered points are there but no connector. I was wondering wether I could remotely locate the batteries or a power supply in my loft so that I would not need to work from a ladder in the future as I age. I had problems with the siren tamper triggering an alarm previously and from advice from this forum (I think) shorted the tamper switch to overcome the issue, possibly caused by window cleaners knocking the box of of alignment. Xould this cause any issues, other than the obvious risk of tampering with the siren?
