Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
hi we have Denso tape around a radiator pipe the pipe is behind plaster and has caused a stain , how can I get rid of it ,obviously the pipe warms up and this has caused the leak .thankyou
Is the pipe still leaking or has the denso coating just bled through the wall covering? If it's leaking then I'd be repairing the pipe. If the tape is bleeding through then as it's usually petroleum based, you will have to use a solvent based sealer and then paint over it.
