pipes in walls ?
13 May 2008
West Midlands
i need to sink some pipe work into some plastered walls , what is the best way to protect them from corrosion ? can i tape them and if some , what tape is best to use , duck or denso ? thanks for any help :idea:
Not the best to sink them in but if you have to put them in trunking.
Barrier pipe would be best as the plaster will not degrade them. Even better, use the conduit designed for the job.
If you use copper, Denso them.
