Right people, long story and endless crap from British Gas.
Cutting it short. The boiler started making banging and cracking sounds when hot water was run or heating was on. Then few days later hit water was not getting hot enough to wash in.
I live is a very hard water area. So was advised scale was the problem. Changing the DHW Plate Heat Exchanger was advised, I changed this, and hot water was steaming again, great news.
So was advised to de scale the Heating, so on Saturday I drained the system, and gave it a main flush, added a de-scaler that says leave in for upto 1 week. Filled up again to 1.5Bar. Now today it started cracking and banging again when the heating was on, noticed the pressure had got upto 3.5bar.
Can the de-scaler cause this? I poured some of the descaler into the old DHW Heat Exchanger and I could hear it fizzing, so I guess the same must be going on in the boiler. I bled a rad to reduce the pressure it is nor at 2 Bar. What I did notice is while it was banging and crackleing, the pressure needed was jumping in time with the bangs, is this a sign of another problem?
Any help would be great.
Cheers,
Will
Cheers,
Will
