designer radiator fitting advice
5 Jul 2006
Leeds
I've ordered a fancy designer radiator (1800mm high x 500mm wide) and just want opinions on the best way to get the pipework to it.
Is it best to run the pipework up from the floor to the valves like with a standard rad or would it be better to chase the pipes into the wall so they come out behind the radiator?
If I chase the pipes, is it OK to use speedfit plastic pipe with speedfit elbows where the pipe comes out of the wall or is that a definite no no? I was thinking of burying them quite deep then just plasterboarding over and skimming level to the rest of the plaster?
Cheers
Rob
Cheers
Rob
It depends entirely on what you'll be happy with Rob.
If you're happy with speedfor connectors, so be it, some people want radiator tails hidden into the wall, and some prefer chrom pipes dropping doen inot the floor.
One thing I would be sire of it that all the pipework is sounds and tested for leaks BEOFORE any making good is done, i.e. plastering painting etc.
How does that sound?
Thanks for the reply.
I think we would prefer the pipes coming out of the wall. My only concern was having speedfit elbows behind the wall - are they reliable enough?
They are fine mate, just make sure ;
1) They are branded (ie John Guest, etc)
2) You tighten up the "collar" on the fitting after you've made your connection.
Have you considered the heat output most of these types of rads are useless at actually heating a room
Thanks for the advice. Got some JG fittings so will use those. As for heat output, it was hard work finding a tall rad with good ouput but found a MHS one with over 7000 btu which is plenty for our smallish living room
Cheers
