desktop died
19 Nov 2008
London
just looking for some advice not to technical please.
i was installing a wireless router on my desktop,i had just pushed the large plug into the correct socket in back panel,then pc turned it self off.
now unable to turn desktop back on.
ok when i switch the mains on.on the front button just a green light appears.nothing else.
before this stopped working on first start up a loud whizzing noise could be heard and a shove on the case stopped the noise.
any ideas,thanks :idea: :idea: :idea:
its just a bog standard desktop.
21 Oct 2004
Please post a photo of the "large plug", and the place that you inserted it.
13 Dec 2008
Lancashire
Sounds like you have blown your psu, is there a switch on the psu (red) this alters the current between 210/240 volts if you get this wrong your in trouble computer should be ok just need new psu.
7 Oct 2007
Yorkshire
Possibly
There is sometimes such a switch, but it switches the voltage between 110 and 240v. Current is current, voltage is voltage
Not sure how any of this relates to the OP other than that they MAY need a new PSU
13 Dec 2008
Lancashire
Possibly
Not sure what your problem is, yes I got the volts wrong by a typing error I also say is there a switch on the psu, and as to how this relates to the op if he has blown his psu he simply needs to buy a psu and not a whole new computer :) pull your head in mate.
7 Oct 2007
Yorkshire
Possibly
The fact that a green light is appearing when mains is switched on would suggest that the PSU hasn't blown though, wouldn't it?
A way to check if the PSU has blown would be (with mains connected) to use a multimeter to check between the purple connector on the ATX (vsb) and any black wire. If 5V is present, the PSU hasn't "blown"
10 Jul 2006
Clwyd
Not neccesarily. It might not be dead, but it could certainly be faulty.
Again, that will tell you that it is not totally dead. But it certainly won't tell you that it is working as it should.
Anyway , this is all academic as the OP hasn't answered any of the questions, so you would assume he's binned it or fixed it.
