Hi all, Just looking for some advice / suggestions. I want to build a garden outbuilding for use as a games room / gym / tv room, for the children!!. Have spent quite a while looking at kit form garden offices and log cabins but would like to self build. I am going to keep at least 1m from boundary's, under 30m2 floor, less than 2.5m high, less than 50% of total garden etc..
So the building I am wanting to build would be 7.9m x 3.9m x 2.5m high.
I am intending to build a timber frame with flat roof with well insulated floor, walls and roof. At this stage I am concentrating on the base, obviously I want to have as much headroom as possible inside so was looking to build the timber frame onto an insulated concrete slab, would this spec work? from the top down, 150mm concrete slab with A142 mesh 40mm from top, 50mm thick jab floor insulation, 1200 gauge dpm, 30mm blinding sand compacted, 100mm crushed concrete compacted. I was hoping to make the top of the concrete slab flat enough to tile on to, and the top of the slab would be approx 30-50mm above ground level. I realise this would be a lot more digging out than laying a concrete slab and putting bearers on top with insulation between, but am looking for maximum headroom.
Thanks in advance. P.S. once I get the base sorted I will be back with more questions on the wall and roof construction!
