dewalt chop saw conversion?
30 Mar 2009
Bradford
hi all,
after a bit of advice if anyone could help.
my trusty 240v dewalt dw708 type 1 chopsaw has died on me :( iv tried to source a replacement armature and field aas they are the faulty parts but found they are discontinued.
i can however buy 110v armature and field, is it a possible conversion? obviously i would change the plug to 110v as well. the parts lists i have checked show all the same parts irrespective of voltage except armature and shield.
if it can be done i could do it myslf easily and for less than £130. much cheaper than a replacement saw :(
any advice appreciated, cheers
I can't see why not - assuming you have a 110v transformer, of course! Just check the capacitor value across the switch, if there is one.
John :)
Switch is probably different on 110 volt because of the higher amperage
