    Dismiss Notice
DHutch about Megaflo Air Gap etc
Discussion in 'Plumbing and Central Heating' started by dhutch, 25 Jul 2019.
  1. snb
    snb
    10 Oct 2007
    3,248
    Thanks Received:
    959
    Norfolk
    Country:
    Servicing wouldn't have stopped it. But as per terms and conditions they required yearly service for warranty. Heatrae are very lenient. Most other manufacturers would have just No. The cost for not servicing is going to cost about £500 could have been much more.
  2. dhutch
    dhutch
    12 Oct 2011
    1,654
    Thanks Received:
    101
    Wirral
    Country:
    I get that adding a external expansion vessel to this tank doesn't solve to problem. But it is the alternative to having a internal baffle in the first place.
    Absolutely servicing wouldn't have prevented it. However if it's conditions of the warranty, as said, a lot of companies would use it to get out it all together.
    Daniel
  3. Sponsored Links
  4. dhutch
    dhutch
    12 Oct 2011
    1,654
    Thanks Received:
    101
    Wirral
    Country:
  5. ianmcd
    ianmcd
    15 Aug 2010
    23,966
    Thanks Received:
    10,066
    Livingston
    Country:
    This is why it is against site rules to Hi-Jack posts, you have completely confused things and you will not get the correct answer, you have at least two posts going asking the same question, which is also against site rules, and for very good reason, you seem determined to have a Megaflow so just do it, you dont need anyone's permission
  6. Sponsored Links
  7. dhutch
    dhutch
    12 Oct 2011
    1,654
    Thanks Received:
    101
    Wirral
    Country:
    I didn't hyjack a thread, I ask for follow up on a 6month old thread as I had been linked to a past thread as was after some first hand information. My post stated it was an old thread and I was after following up info.
    I'm just trying to work out if this is a reputable brand that's so common there as (as ways) some issues, or if there are loads of issues masked by good marketing. Because our plumber has suggested to go with a Megaflo.
    Just trying to work out what's cylinder to with, give it's £1200 of a £2500 job.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
